Re: where to install the transducer for fishfinder?
An ideal spot would be on the flat part of the hull, typically the pad if your boat has one. It can't be at an angle. If you don't have a flat spot then you need a transom mount xducer and it has to be mount where there's no water turbulent (sp?) There should be plenty of threads in the electronics section covering this subject.
