where to get rubber to cover guide-ons
jajeeper
I recently bought a boat and the trailer has very nice guides that stick up about 2 feet above the trailer making it easy to see when loading the boat. <br /><br />
<br /><br />As you can see, however, these guides are made of about 2 inch angle iron. So, the first time my boat touched one of them when I was loading it on a windy day I scratched the paint a little. <br /><br />I'm thinking the least expensive way to remedy this situation would be to find a few feet of some big rubber pipe (like maybe 4-6" diameter), cut it in half, and secure it to each of the guides. I can't find any rubber pipe that large. The home stores only carry little stuff. I would prefer rubber over that plastic drain tile. <br /><br />Any ideas who might carry such large rubber pipe or any other ideas for softening the guides.<br /><br />Thanks.
BoatBuoy
Re: where to get rubber to cover guide-ons
How about heavy carpet fastened w/nylon wire ties.
jajeeper
That might work. Hummmm.....
kayakndave
I would just go down to Lowe's or Home Depot and get the foam pipe insullation tubes. They are split with the adhesive already applied on the edges - so all you have to do is wrap around your guides, stick the edges together, and your done! I use them on my bimini frame to keep the "HOT" frame from melting my curtains - works like a champ and CHEAP!
JB
I suggest 4" white PVC pipe, JJ.<br /><br />Low friction, no marks on the boat.<br /><br />Good luck. :)
wayne h
Master Chief Petty Officer
i also use pvc works great for me
dajohnson53
Yes, PVC pipe is the way to go. I happen to use black because I had some on hand, but white might be better in avoiding marks. I looked at buying some "ready made" ones from a boat store and saw they were just made of PVC pipe with end caps on one end.
