Where to buy connection rod piston Force 90HP
berndie61
Where i can buy the connection rods between crankshaft and piston ? It's for an Force 90 HP outboarder. OEM part number is 600-818052T6.
Berndie61
berndie61
Re: Where to buy connection rod piston Force 90HP
I found now the original part number from Force which is 600-818052T6.
Frank Acampora
Welcome to iboats Berndie.
When I hear people looking for connecting rods, right away my suspicions are aroused. Why do you need a connecting rod? Most repairable conditions on these engines do not involve the connecting rod.
The connecting rod is the outside race of a bearing with the crankpin being the inside race and sixteen rollers in between.
If the big end of the rod is corroded or spalled or otherwise worn or if the rollers are worn or damaged, there is a good chance that the crank pin is also in poor condition. If that is the case, it is not wise to replace the rod.
So before you go investing money for a connecting rod, double check the engine and crankshaft condition.
berndie61
hello Frank Acampora
I need the connection rod because the smaller end of the rod where the piston is, there is my problem. I rebuilt the powerheads in 2004 first time. In 2004 I used wrong piston pin spacers, which result in a damage of the piston this year again. The pistons were burned. The piston pin and the rod are bluish, the hardness of the rod is gone. There is no problem on the crankshaft.
Berndie
