jimmyzshack
- Apr 3, 2008
- 24
ok this sounds dumb but where should i attach the anchor rope to this boat? Will the side cleat work ok. I will be anchoring in pretty strong currents sometimes.
Is that a center cleat I see behind the horns? If it is, that's the place, but you should also have a set of bow chocks to led the anchor line over the bow. I don't see any of those.
http://www.iboats.com/Skene-Bow-Chocks/dm/*******.065157527--**********.807052395--view_id.39738
You'd mount them on either side of that racing stripe, close to the edge where the deck turns down to the rub rail Through-bolted to the deck, backed with fender washers. That arrangement and hardware will hold the bow straight into wind and current, which is how you want the boat to ride at anchor.
The cleats on either side of the bow will probably work okay, but you'd be better off setting things up as I described above. NEVER anchor from a stern cleat alone.
Good luck!
Do you think there will be enough meat under the center cleat?
