Where should I post this?
slarson1us
Sorry, but I'm not sure where to post this. I have an old (1993) Ocean Air 17000 BTU unit in my 32’ Bayliner Avanti. Last weekend I tried it for the first time this year. I’ve always had to prime the hose from the pump to the compressor, and this year, when I tried to use turn it on by hitting the “run” button after selecting the cooling temperature, it tripped the breaker. I reset it a couple of times, with the same result. The last time I tried, the digital display on the control went haywire, showing a couple of different numbers before settling on a “1”. It now fluctuates between different numbers, none of them close to the real temperature. The pump doesn’t seem to be pumping (I took off the line leading to the compressor) either, but I’m not sure it would until the unit came on. Any ideas?
Don S
Re: Where should I post this?
Boat topics...... you already have a post there.
