where is the flush port on 1993 waverunner 3
jones183
this is my first jetski and it is in pretty good shape but i cannot find the flush port where you plug the water hose to flush the system after you ride. I did not get an owners manual with it that has that kind of info and cannot find one to download. any help would be greatly appreciated i want to run it before i launch it and have problems. i cannot find the answer anywhere on the internet and believe me i have tried for hours.
Jones183
skysurfer2010
Re: where is the flush port on 1993 waverunner 3
Check the cooling line that comes through the transom. There should be a T off that line that is capped. If there isn't, then it doesn't have one. You can purchase a flush kit online and they're easy to install.
I'm not sure if they had them back in 93, but Yamaha typically has a male end on the flush kit that kinda looks like a lower case T that you would push into the female part of the flush kit that goes to the water cooling lines. If the previous owner neglected to give the connector to you your local Yamaha pwc shop should carry it.
mmccoy555
Some of the flush connections were under the seat coming through the top of the machine. There is a special flush kit hose for those. it should be a round connection with two slots on either side of the inner diameter.
artificialreef
if you havent found it by now pm me. I have a wave 3 with a flush on it and i will look at it.
