Where is my post and why do I have to sign in several times?
Something is messin up. I post a new thread and it may appear for a few minutes then later I look for it and ITS GONE,,,whats up with this? thanks:confused:
JB
Re: Where is my post and why do I have to sign in several times?
Was it naughty? Maybe it was Zapped.
As for needing to sign in several times I don't know what to tell you. That is not a Moderator's doing.
I never say anything bad or rude ,I make sure I stay away from politics and social issues as well.......Im here for boats and others who enjoy the hobby.
Vlad D Impeller
Those darn little greenies again. ;)
SPINNER!!!! :D
tashasdaddy
have you been shutting down or is your computer automatically restarting. when it does that , it sometimes loose the cookie for the auto sign in. as far as the post i have no idea.
Bob_VT
I presume you have iboats saved as a bookmark in your favorites.....
After you sign in again..... save the iboats in favorites AGAIN and it will ask you if you want to overwrite the one already saved and say YES.
Once in a while the computer will screw up your saved listing ...... happens alot when you get an update from microsoft or some other program.
SpinnerBait_Nut
Make sure your bookmark says http://forums.iboats.com
As far as your posts go, try refreshing and then see if they are there.
After you set the bookmark.
oops!
check the settings in your puter
make sure it says allways check for newest page or somthing like that.
your puter could be reading the page from your temp int files. if it is... you keep seeing old info and would have to sign in any time you wanted to post a note. even after u posted your puter would still bring up the old page.
if it is you continually have to hit refresh. change that setting,(it can slo u down a bit) and you should be good to go.
as for loosing the post. it doesnt uasually happen.
i lost one on here once but it was here, i just couldnt find it.
cheers
oops
(refresh)
cheers
oops
