Where is fill port for trim?
RampeyRanger
Hi folks. I have a 1990 Ranger with a 150hp Mariner. It has a square trim pump in the boat, and a single ram lift cylinder. There is no reservoir. How do I add fluid? Thanks!
Boyce
RampeyRanger
That's what I was afraid of. Mine appears to be hard plastic like the old bakelite stuff distributor caps was made off. The top is broken off. Normal removal means now impossible. Can I drill and use a screw extracor/EZ out? Do I just fill it up and put a plug back in the hole?
roscoe
ez out may work, then buy a new cap
good luck.
and welcome to iboats.
