where does the water come in?
Maker Scream
I'm the new owner of a Force 85hp model# 856X5L . I'm ordering a manual but i need to know where the water enters the motor? I have a set of water muffs to attach to the garden hose so i can do a few quick checks on land before i end up stranded out in the middle of the lake. But the area where i would normally expect to find the water inlet, has Fill & Vent holes for the lower unit oil. The next location that i thought could be the water inlet was just in front of the prop. I thought i should ask yall before i screw up and overheat my motor before i even hit the water. Does anybody have any pics or first hand knowledge of where it is on this motor? any help would be greatly appreciated. thx guys :confused:
SweeperForce
Re: where does the water come in?
I've seen them in only two spots. On the strut(duel exhaust I believe) or in the gear case. (single exhaust).
Tom
Maker Scream
Mine is like the white one and the vent you're pointing at was my guess. Maybe I'm smarter than I give myself credit for. Thanks Tom!
jerryjerry05
Since your NEW!!! First pic is the NO touch.Second is the oil drin.
There is a screw on the side of the drive/front.DON"T remove!!!
That's part of the linkage and you won't be able to shift if you remove.
Also pics help.
Profile,Location? You might be close to someone who can help?
Maker Scream
Thanks Jerry. Being a noob, I need all the friendly advice I can get. I'm pretty sure I would've touched the no touch screw before the week was up. Happy Boating
