Where do THESE go?
drackley
1994 Evinrude 115 cross flow. Just finished rebuild from basket case, and did fairly good on figuring out where things went. However I have two small hoses, and four tiny hose fittings to accout for. Two fitings one each in the top bypass covers, one in the intake manifold pointing down, and one in the side of the crankcase cover. There are also a couple of hoses tee'd from the bottom of the carbs which I'm assuming go to the fitting bellow the throttle linkage. Thanks in advance for telling me where to put these ;) . Dirk
