Re: Where do I spray starting fluid?
What motor is this?
If it's a 2 cycle, where you mix the oil with gas, you "can" give it a
little shot of starting fluid, but it's not great for it, because it doesn't get any lubrication if it doesn't have fuel mix right behind your starting fluid.
Can you describe your issue a bit more?
If you've got good spark, and it's getting adequate fuel to the carb, there's generally no need for starting fluid. I'd do a little more looking before trying to get it running on starting fluid.
Otherwise, if you insist
you can spray right into the carb(s)- but only for a second or two (it's not great for your engine). OR, you can shoot a little bit right into the cylinder(s) by removing the spark plug(s), and then, of course, quickly putting it/them back in (starter fluid evaps pretty quickly).
What engine?
Jeff
