It seems that a local outboard place might want to charge me a little too much for parts for my motor...
I do have one other option about 40 miles away that I haven't asked, nor taken the motor to, yet, but I might as well ask here:
I have a Johnson 6HP, Model 6R79E, Serial J5099795 that is basically brand new (believe it or not - total hours on the motor have to be around 12, 10 with the previous owner, 2 with us).
I'd like to get an impeller (kit?), or water-pump kit (whatever it needs), and a guess a carb kit (just in case the gaskets are leaking or something... the carb looks clean as it sits on the motor).
How do I go about getting the correct part numbers? I see I can order from a few places... not sure about the best place for prices yet.
Yes, I am serious about the 12 total hours thing... I'll see if I can provide pictures here.
I feel a little bad about using it 'cause it's so clean. Still has the original splotches of grease/lube around the carb, too.
So I want to run it - but run it right so it lasts.
Any suggestions would be appreciated.
