Where can I find Evinrude Simplex Control spare parts?
comstox
Part identification for old Johnson/Evinrude linkage control
Hey guys, I'm sort of stuck here. I have found a wealth of information here on iBOATS and any time I need a Merc of Johnson/Evinrude part, I can just jump on the manufacturer's site, drill down the list, find my part and it's corresponding number. BUT... I have an old Sea Nymph with a 1981 Evinrude 35 and it took a LOT of pressure to put it in reverse. One of the cogs for the Neutral safety start shifter was worn and I pulled too hard and broke the piece INSIDE the front control mechanism.
Wow... I wrote a whole chapter just to ask: WHERE CAN I FIND PARTS LISTS TO OLD Evinrude Simplex Controls??? i THINK the piece I need is called a cable guide? If I could post pics or add links I would.
Any idea who has parts like that?
I'd say the background info for the control is mid 70's to 80's The boat itself is a 1994.
I added a link to show which controller I am talking about.
THANKS IN ADVANCE!
Glen in New Hampshire
comstox
I still can't add pics, but I attached a link to a pic in my craigslist post. You can see the controller near the steering wheel.
My question? Where do I buy parts that are in my control box? While putting/forcing the lever into reverse I broke the end off my guide thingie.
Thanks guys!
comstox
Guys I didn't mean to post this. The page said it lost my changes so I posed a new shorter post. Can someone just delete this post? Thank you!
Glen
Fed
BRP Website in the drop down menu where you would normally pick johnson or evinrude select OB Accessories instead.
F_R
Pre-1979 cables and guides are different than 1979-up.
F_R
The link doesn't bring up a specific item.
But any Evinrude dealer or here at iboats should be able to help you with the part. However you need to know if it is a pre-1979 or 1979-up. The cables are different. The pre-1979 cable guides are removable. This assumes the control with squared corners. The real old ones had a rack-and-pinion cable.
F_R
No Title
This is the pre-1979 control
flyingscott
Why not just replace the box with the 78 and newer single lever model. A lot of used ones for sale.
comstox
I think it MUST be post 1979 as it does NOT have rack n pinion but a rectangular 6" plastic slide that my cable runs through.
comstox
$$$$$ Cha-Ching Cha-Ching Cha-Ching $$$$$ I only need one little $10 part. I was hoping to just replace the bad part.
comstox
I FOUND IT!!!!!!!! Thank you! I sure wish I could post pictures to show you, but I clicked Outboard Accessories and my year (1981) and WHAM! There it was!
Thanks again everyone!
