Where can I find details on removing my engine
marionr26
Looking to remove my 717 rotax out of my speedster jet boat. Does anyone know where I can find instructions on steps in removing it
Jeff Walkowiak
Re: Where can I find details on removing my engine
it is simple to do,, probably a good place to look would be www.sbtontheweb.com they have a lot of tec support on the site for removing engines
marionr26
thanks again jeff I got something off one site but its for removing out of a jet ski and I dont see anything on removing the drive shaft thats mainly what I think I would have a problem with....Ohhh SBT that is where this engine came from manufactured engine from them. It was in it when I got it. I really need to learn how to work on this boat if Im gonna keep it the older boats seem to require alot of maintenance
Jeff Walkowiak
you have jet ski engines and pumps you just have more room to work that's basically all the difference,, you may even be able to slide the engine forward and off the driveshaft once you disconnect everything
