I have a new 5.7 engine. It has about 50 hours on it.
The old engine was leaking oil and got the bilge pretty nasty. i cleaned some of it up but not anywhere close to all of it.
If there is just a little bit of water in the bilge I dont see any oil in the water. But if the bilge gets a inch or two of water in it I can sometimes see a little "ring" if you will of oil around the water line.
I have good oil pressure. I changed the oil at the first ten hours. When I checked it today it was just a hair under where it was before on the dipstick. I only had to put about 1/8th of a qt in it to bring it back to right at the top line on the dipstick.
so I will continue to monitor the level and I have tried to put one of those white oil abosrbing cloths down but I dont see anywhere where its actuall dripping down.
Where would be some good spots to look for oil on the engine?
Thanks
Thanks
