Where 11" pitch propeller for Tohatsu 18hp?
teppokotila
I have a 380 metre inflatable boat with 2-stroke Tohatsu 18 hp -00. I don't have a heavy load so I should get a propeller with more progressive pitch. Now I have 9" pitch and the maximum available for this model is only 10"! I should get 11" or 12" pitch. Where could I get one? Can I use some other outboard models' propeller - are they compatible (and how do I know if they are)....? Any other possibilities?
clanton
Re: Where 11" pitch propeller for Tohatsu 18hp?
You should run engine with tach and prop to proper rpms. Not much out there for this engine, could take to prop shop and change pitch 2 degrees.??? Talk to a prop shop in your area.
