Gunther Boo
- May 29, 2011
- 5
I have a 1984 Johnson 40hp outboard ( model # 40ELCR ). I replaced the bad lower unit with one from a 1981 50hp Evinrude. It fit perfect. The only problem is when I shift the controller to forward the prop turns in reverse and when I shift into reverse the prop turns forward. I 've taken the shift controller apart and studied the cables and can't see any way to make them work in the opposite direction. The engine won't throttle up all the way since the cable doesn't travel far enough in forward gear ( reverse on shift handle ). Any ideas?
