when carb is leaking?
I have the top carb on my mercury leaking at the throttle shaft that goes down to the bottom carb. I was told it is worn and it cant be fixed and i should buy a new one is this true?
LubeDude
Re: when carb is leaking?
The float is probably sticking in that carb, there is no other reason that that much fuel should be in that area in the first place.
Mike722
The worn throttle shaft should not cause the leaking fuel. However, a worn throttle shaft can cause other problems and maybe that is why they said replaced the carb.
tha's what they told that once it is worn down it will cause a rough idle. should i replace it with a new one ?
JUSTINTIME
yep8)
JUSTINTIME
yep, not fully closing i would think
price them out and tell us here
AMD Rules
Why not simply replace the seal on the throttle shaft ?
AMD Rules
What is the HP and serial number of that motor.
Assume when you refer to $300... you're talking about replacing the whole carb body, or are you just replacing only the throttle shaft & seals?
Chris1956
Boatrookie, It would take a lot of wear to make the carb unserviceable, due to air leakage past the throttle plate. Is there any play in the throttle shaft? Normally if you set the idle mixture correctly, it will compensate for any air leakage.
LubeDude
What # carb is it, is it for a V6, I may have one for you.
