Hey ya'll, I just pulled the boat into the garage for a little PM and noticed I needed grease in the hubs. As I was adding the grease, the bearing buddy wasn't moving. Bad wheel seals I thought. so I pulled the wheels and hub and notice that the hub had a lot of play in it on the axel. It didn't seem like the hub was seated all the way on. the pin was in and the nut was not tight on either side. One side wheel seal is completely chewed up but the other side was good, I just cleaned the hub, bearings, seals, and axel and repacked. seems tighter noe and ok. I'm going to replace the seals and bearing on the other one. shoudl I be worried about this happening again, even if I tighten the nut a little tighter. shoudl I just replace the hubs altogether? Anything else?
