Wheel Hub Type
Roscoe_Floyd
Could Any one help me to find out what type of hubs these are. As you can tell I need end caps for them.
They are not Yacht Club I called them.
Thanks for the help.
Roscoe
Roscoe_Floyd
Re: Wheel Hub Type
Sorry about that I tried to attach a couple of pictures so you could see the hub. Maybe someone should help me with inserting or attaching pictures to my posting. Sorry for the trouble, I tried, thanks for the help.
Silvertip
Re: Wheel Hub Type
You have to have your pictures hosted by someone like Photobucket.com and then post the link to the photo here.
Roscoe_Floyd
Re: Wheel Hub Type
Thanks, I thought I could just attach them here but as we
see that did'nt work, Again thanks, sure will
Silvertip
Re: Wheel Hub Type
The wheels have been equipped with Bearing Buddies that have been seriously misused. This mess needs to be cleaned up. Chances are the back side of each wheel is also a mess. If that's the case, new seals are required. Bearing buddies need grease added only to the point where the center disc moves slightly. Any more than that and seal failure will occur. Rubber caps are available to cover the Bearing Buddy but lack of them are not the cause of the mess. Caps are available at most discount stores and sporting good stores that sell boating supplies and equipment. Any marine dealer should have them as well.
Roscoe_Floyd
Re: Wheel Hub Type
Thanks I don't know why these people around here don't know that. I can't find those caps you talk about anywhere
any ideas. I've not contacted the mariane dealer over yet but I will today. But thats why I'm glad I joined this group again thanks for your help.
Roscoe
Roscoe_Floyd
Re: Wheel Hub Type
Hi Rick,
That is out bleeping standing,,,, Ok as you can tell I'm new to all of this. How can I get these off and I will service the wheels and all I need is caps put back on.
Thanks for the help with all of this.
Roscoe
rickdb1boat
Re: Wheel Hub Type
Using a rubber mallet or a regular hammer and a piece of wood, tap sharply on one side and then the other, working your way around the buddy bearing until it comes off. Sometimes they can be on pretty good...They are just a press fit in the hub....
Roscoe_Floyd
Re: Wheel Hub Type
Thanks Rick,,,,,
I go to the Cub / Card games all the time over there next time I'm in the beer is on me.
Thanks
Roscoe
rickdb1boat
Re: Wheel Hub Type
Where do you boat? I See you are north of Chicago. Been to Wrigley many times....
Silvertip
Re: Wheel Hub Type
Bearing Buddies are an interference fit in the hubs and as such are driven on and likewise must be driven off. Use a dead blow mallet to tap around the housing. It will eventually fall off. Place a piece of hardwood against the end to drive them back on.
rickdb1boat
Re: Wheel Hub Type
Whew. Thanks for explaining that more clearly, Silvertip..........
Roscoe_Floyd
Re: Wheel Hub Type
Thanks to both you guys!!!!!! I don't know why these people around here don't know whats going on.
But again thanks for all the help and I'm trying to get out
to lake Michigan but the boat is to unreliable, I mean
look at the wheels. For now I'll end the season put putting around a rock cut state park, but the fishing sucks.
I knocked them off and slapped new ones on and cleaned the hubs up and it works perfect. I'm getting new hubs this winter. What a great group to belong to!!!!
