Any PM ideas to reduce or eliminate brake cylinder (wheel) seize up? Have a Trailmaster single axle with a Rinker 212 on board. Had a grease seal blow off on the Starboard side. After a bearing replacement (at the ramp) got it home and while adjusting the brakes I discovered the port side brakes were not working (cylinder seized) Quite sure the seal was a overgrease issue on my part, the rest is a mystery.
