i HAVE A 50 HP EVINRUDE MOTOR IT IDLES ROUGH BUT SEAMS TO RUN GOOD AT HIGH SPEED. I HAD THE CARBS REBUILT, BOUGHT A NEW TANK AND LINES, CHANGED THE PLUGS AND DID A COMPRESSION CHECK. you can pull the plug wire off the top cylinder and the motor wants to die but pull the plug wire off the bottom cylinder and not much affect at all. whats wrong?? they said it might be the fuel pump???
ab3838@aol.com
