I have this 55EL76E motor and a repair manual for a 55EL76. I started to troubleshoot the stator today and found two extra wires attached to the posts. I pulled the electrcal box off and found what appears to be some homemade device behind the box.
This device has 3 wires coming out of it, a yellow, yellow/gray, and what looks like a black wire but might be something else that goes to the bottom of the wiring terminal and attaches to a light purple/green stripe wire that goes into the wiring harness. It is potted in epoxy that looks to have been molded around the components by hand.
If I ohm the wires out they ohm out like the stator wires, 1.6 on tthe lowest setting on my VOM.
The stator ohms out as good and the rectifier also, but I still only get 11.something volts on the battery with the motor running.
I bought a DVA adaptor for my meter but don't have any water to run the motor where I keep the boat.
Can somone help me get to the next step here to try and get this motor charging.
