whats the easiest way to tell if you have a scored cylinder(s)? today as i was going across the lake, at about 3/4 throttle, my 1999 125hp merc slowed down like it was running out of gas. i shut it off to see what happened. still had gas, the overheat buzzer didn't buzz, i had good water pressure the whole time. got back to the dock and checked the plugs. the top 2 look fine, number 3 looked a little gray on part of it, and the bottom plug was grey and dry. a compression check showed 120-125psi on all 4. put in a new set of plugs and she started and seems to run ok. i'm worried what could have happened and don't want it to happen again...
