PiratePast40
- Mar 21, 2009
- 1,734
I'm seeing a huge price difference in condensors. For example, for the Volvo AQ130 4 cyl engine, Volvo lists 2 condensors, depending on the distributor. List prices are $27.25 ( PN 24170) and $49.12 (PN 834545) respectively. Both models of distributor use the same coil. I can find both on ebay for less but the later still commands a $35 price tag. Both have the extra wire running to the coil so that's not the issue.
I was under the impression that a condenser was matched to the coil. If that's the case, the only difference should be in the way it's mounted or wired. I can find automotive condensers at a much lower price but not necessarily the same Volvo part number and want to make sure that the rating is the same.
Anyone know about the rating and how it's determined?
