4-bld usually helps some with hole-shot, mid-range economy tends to be slightly better, but unless you have an outboard and can raise engine heigth, you'll lose some top-end, in most cases.
It's all in the prop design...some will be better than others...
Something like a stiletto Bay Pro in the correct pitch will actually let it unload at mid-range and the result will be better fuel economy.
