Re: What's that squealing? Oil pressure alarm?
I have a '98 Regal I/O 2100 LSR. There's an alarm
That starts when I turn the switch key on and
(usually) goes off after the boat is started.
Does this have to do with the oil pressure? ..and if my oil
is okay, how do I disable it?
Welcome to iBoats!
Howdy,
If your oil pressure is "ok", you need to FIX it not disable it.
You didn't indicate what Make Model series of the engine and drive you have.
If you have a Mercruiser from that era, It very likely has a High temp, Oil pressure and possibly a drive lube monitor all connected to the same alarm circuit.
The circuit is usually a "ground-to-operate" circuit......meaning that each alarm sensor simply goes to ground when it reaches it's own limit.
You'll also get an alarm if the common wire connected to all the sensors becomes frayed and is grounded anywhere along the way.
You need to fix the problem. Not disable it!
Regards,
Rick
