Motor type OMC 115 with VRO. It is a 1994 engine and is called the turbo jet. Engine compression is 120 in all 4 cyl.<br /><br />At idle, and infrequently, there is what sounds like a clunk. It is as though the motor skips just the smallest amount. The sound does not persist but it will do it randomly. I indexed the flywheel and checked it out with a timing light. Each cyl. fired when it was supposed to at idle and at 1500. Any ideas what that sound might be???? Also, the motor will loose RPMS (800) off of W.O.T after about 20min. The power pack will be replaced just because, but I wonder if the two are related?
