What's Cruis Throttle?
Evinrude Boater
I was reading the sales brochure for my 1964 Evinrude 75 hp Speedifour and it advertised that it has cruis throttle which reduces gas consumption when cruising. Does anyone know what this is? Is it just a gimmick? My 16 foot fiberglass boat is on a small (60 acre) water skiing lake and I pull the kids on a tube. I can burn half a tank going 8-10 times around the lake. Is this normal? This is my first boat so I have nothing to compare it to. I wondered if "Cruis Throttle" could help me save gas.
tashasdaddy
Re: What's Cruis Throttle?
any engine is going to be more effiecent at 3/4 throttle a than WOT. never heard of cruis throttle, pulling a tube, with that fantastic nearly un killable engine you are doing about par. the tube is a lot of drag. teach them to ski and get a little better mileage at 3/4 throttle if you can get the tube up and see if you can feather back on the throttle and still keep them happy.
itstippy
"Cruis Throttle" is not just a gimmick. It's a carb setup that does just what it advertises - reduces gas consumption considerably when cruising. To trip the carb into the proper setting you get the boat going full speed at Wide Open Throttle (WOT) then back off to 3/4 throttle. Your RPM's drop only slightly but your gas consumption drops significantly.
You can't get the "Cruis Throttle" set by just going to 3/4 throttle. You must first got to WOT, then back off to 3/4 throttle.
tashasdaddy
thanks itstippy , thats the technique, is was trying to convey, but in 45 years of boating never heard it call that. learned something again
Joe Reeves
As "itstippy" states..... That's how it's done. What actually happens is that at full throttle, the spark advance and the throttle butterflies are at their fullest setting.
Fron that point, dropping the throttle back to approxixmatelly 3/4 throttle reduces the throttle butterfly setting down to approximately 3/8 open but the spark advance stays at its full spark advance settting.
Many year ago, with a engine identical to yours, on a 17' fiberglass cabin Dorset, I experimented on both settings and found the gas consumption to be as follows.
Full throttle = 6 gal fuel = lasted 50 minutes
Crusing Range = 6 gal fuel = lasted 1 hour, 45 minutes
Quite a difference with not a great loss of speed.
tashasdaddy
i had been taught the technique, but in all the years never new it had a name, just new it worked.
Evinrude Boater
You're right!!!:D I've taken five adults around twice each and I'm at around a half a tank. Thanks for the tip.
I thought I had to go full out for adults to have fun. I guess it's hard to shake the "pedal to the metal" mentality.
Joe Reeves
At $3.00 a gallon, the shaking gets a little easier!
Evinrude Boater
3 Bucks, is that how cheap gas is in Florida?. At $1.10/litre we're paying $4.20/US gallon or $5/Imperial gallon in Canada. Factor in $2 for oil and it's about $27 per tank.
My neighbour says I should cough up a few G notes for a 4-stroke. To save gas? I can buy a lot of gas for that kind of money!
I'll keep my simple 2-stroker thanks.
Classic Boater
whywhyzed
Banned
don't forget our dollar is only worth 90 cents tho', and there's only 3.8L in a US gallon.
1.10x.90x3.8= $3.76 apples to apples....
So, about this cruise throttle...does this technique basically apply to most or all Evinrudes/Johnsons?
jimmbo
It pretty much applys to most 2 stroke outboards. Take off the engine cowl and observe how the spark and throttle linkages move in relation to each other.
Starting at idle, as you advance the throttle the ignition timing advances while the carbs barely move off of the idle stop. Once the engine reaches full spark advance, about 3/4 of throttle lever travel, then the carbs start to open up. As mentioned earlier, pulling back on the throttle lever reverses the order. Carbs close 1st leaving the engine with full spark advance. Since boats need lots more power to go a little faster, to go a little slower takes a lot less power.
During the 70s, the carbs on a lot of outoards were redesigned to reduce the air pressure in the fuel bowl which resulted in leaner air/fuel ratio at part throttle. This was done by applying manifold vacumn to the float chamber. An air bleed regulated the amount of pressure reduction. At full throttle where manifold vaccumn is low, the air bleed allowed full atmospheric pressure in the carb. At high rpm with full spark advance and closed carbs, manifold vaccumn would be high, Applying this vaccumn to the float chamber would result in less than atmospheric pressure inside and a leaner mix.
Unfortunately, what worked well in the 70s with 70s gas does not always work with todays crappy gas. Now the engine is too lean under part throttle condintions and a meltdown often occures. Adding ethanol to the gas doesn't help matters either.
itstippy
Eboater, you probably know this but others don"t. Another way to save lots of gas is to spend time getting the "setup" just right. You get the prop pitch, diameter, depth, and angle set optimally for cruising. You figure out the best weight distribution for your particular hull. Voila! Your rig is much more efficient - way more bang for the buck. Plus it's a lot of fun to do if you like tinkering around with boats. Some of the current & retired racers are experts at this art and have shared their knowledge in previous posts. Search word "setup" in the Non-Repair forum. Anything from Dhadley is golden.
