I'm installing a GM 3.0L w/Delco Voyager EST ignition system in a boat w/1987 wiring harness that used to be breaker points ignition system. <br /><br />Installation guide says connect coil power wire (purple) and shift interrupt power (also purple after conversion from grounding circuit to +12v circuit) to a non-resistive B+ power source. Could someone explain specifically what's a B+ power source and, for future reference, what does the term B+ mean? I can't find it in the manuals anywhere. <br /><br />Anyway, I connected both coil and shift interrupt to the purple wire coming from the ignition key switch (pin 5 at the plug). I spliced in to the purple wire on switch side of the big plug to avoid resistor wire. Haven't got it started yet because it's blowing the 20 AMP fuse in the red/purple wire at the ignition key switch. Not sure the two are related. Any suggestions?<br /><br />Thanks.
