what yrs carb motors
wedge542
Re: what yrs carb motors
33 views and no info,,,anyone know whats the diff in a black max and a reg 225,,, this one is black max offshore with carbs. also it has a plastic plug in the area beside the pee pipe,is this for flushing or use instead of muffs on lower?
Faztbullet
They made a 3.0 225 carb engine from 1994-2001, the 1994-98 was first production run engine and they are ok, the later models are better. They had problems with the CDM (D shaped) modules and fuel supply. That is a flushing port only do not run engine as it doesn't supply enough water to cool impeller, just use muffs..
wedge542
thanks ,,,how is the offshore any diff than one without it on cowl and are all offshores black max?
