What year of my Magnum4
Zbojek
I bought Mariner Magnum 4,( many parts inside and lower unit has Mercury logo)serial number: 9563849, made in Belgium, I don't know what year and hp it has.The label says 25-is it hp or kw?<br />Is it posibble to have only 25kw whit 4 cylinders?<br />It probably had oil injection as the label says but someone has taken this part off, so I have to mix fuel/oil outside- I'm not sure is it 1:50 or 1:100? If it has oil injection, do U know part nr., price , where I can get it? What spark plug I should use, I must buy new carburator gasket kits, but I don't know which model, year?I can send few pictures.Maybe someone has owners/repair manual? Noone knows anything about this outboard in Poland,I couldn't find anything on Mariner site.<br />Please help me !!!<br />Best regards !!!!
roscoe
Re: What year of my Magnum4
Mix the fuel 1:50, using TC-W3 rated oil.<br /><br />I think you have a 1989, 40 hp, 4 cylinder model.<br /><br />Champion sparkplug #5838
Zbojek
Thanks for help :) <br />Any idea if it had oil injection?
roscoe
If it had oil injection, it was an old "Auto Blend" unit.<br />They were a large, boat mounted unit, not very reliable, and messy.<br /><br />You are better off mixing the fuel manually.<br /><br />To locate parts, contact a Mercury dealer.<br />Mercury manufactured your motor.<br /><br />Here is a website for Marine Power Europe, it is the Mercury Europe site. It is available in 8 languages (click the flags at the bottom of the page).<br /><br />Good Luck
Zbojek
Thanks for help, I can't wait to go fishing :) <br />I will let You know what they'll tell me, as far as I know the engine had oil injection under it's cover, if You give me your mail I will send You few pictures. I will tell You why I wanna know about this stuff: After I bought this motor I left it at service for tune up and when I took it back it was without this reservoir, whith normal fuel pump- I am sure they have stollen it, the same says pre-owner, so I need another prove- part nr. etc.but noone in Poland, at the internet could help-model of this motor must be rare, even at Mariner site - noone answers, at normal EPC catallog we couldn't find nothing.So I am happy that You helped me.Maybe You could help me with another thing i.e. I need gaskets for carburetors- they leak, the only thing I found on them is symbol WMA 2b and WMA1b, searching at the internet I found on page glmmarine.com kits for those carburators - but they have 3 kits looking similiar, I am not sure which I should order, I give You GLM and OEM numbers, maybe You Could help :<br />For WMA 4 kit GLM 40640 Oem 1395-9024<br />kit GLM 40653 oem 1395-9023<br />kit 40651 oem 1395-9650<br />Thanks a lot!!!!
Zbojek
Finally I found parts for the carburator here at Iboats!
