what year, newer manifold bolt pattern
Bt Doctur
Have what is supposed to be a running take out a customer droppped off. Need to determine by Mercruiser tag info exactly what it is because the heads only have 4 vertical threaded holes on each side for the intake manifold bolts.Serpentime belt setup also.2005 -2008????
Ser. L 676345
SAV C x
M146519
Thanks for any help
Don S
Re: what year, newer manifold bolt pattern
1999 350 Mag, MPI MIE. Not an outdrive motor, it's for an inboard.
Bt Doctur
Thankyou Don,
next question will be, can I swap back to regular heads .Pretty sure the bolt pattern is standard for head bolts.
Fun Times
ENG serial#: 0L676345 model number 3F495AJM1 1998M MIE 350 HORIZON 630V 2.0 3RSR 350 MAG MPI HORIZ
Warranty Period: 05/30/2001 - 05/30/2002
Product Protection Period: 05/30/2002 - 05/30/2004
Manufacture Date: 04/19/2001
Don S
Not sure what you mean. It has regular heads on it. At least for that model engine.
The 8 bolt intake is what was used on that engine.
Bt Doctur
Need to put a 12 bolt manifold on. Can access a set of heads ,always thought SBC were SBC.
Don S
Probably can, never really tried to de-rate one before.
Bt Doctur
Long story, cust engine broke a crank. Mech took it apart and said it needed a new motor.
Cust finds a "running takeout" from a marina that replaced both motors in a twin under warranty. engine missing intake, starter, flywheel,accessories and pulleys, but this was from a running engine.Cust regains all his old motor parts minus block and heads.Delivers said takeout motor to me and notice his manifold wont work. If the heads on the motor will only work with a MPI manifold ,I need to change heads to use his original manifold and carb setup.
Don S
Nothing has changed on the bolt pattern or water & oil passsages. It should work with no problems what-so-ever.
(he says confidantly from 3000 miles away)
Bt Doctur
Thanks everyone for the replies
TilliamWe
Banned
I agree. While most people go the other way, I am fairly certain you can bolt Non-Vortec heads on in place of Vortec heads. And that's exactly what you are talking about doing. It'll be a "big" downgrade in power.
Ayuh,... Your Customer would be better off,+ Happier if he bought the intake to go with the Vortec heads, rather than stepping Backwards...
JustJason
Correct me if i'm wrong but isn't it usually cheaper to buy 1 intake manifold with gaskets vs 2 cylinder heads with gaskets?
And i'll ask only because no one else has yet. Why was this motor taken out for warranty? Entire blocks are usually pulled for warranty because they either have little/no compression and it's deemed to be a piston, or it's has a bottem end knock.
Hate to see you get burned by putting tons of time into something that's going to knock like a front door by the time you get it all put together and installed.
180shabah
Agreed, he should pop the $150 for the manifold. Sell current manifold on eBay.
PRW
Seems pretty pointless to remove the (better) Vortec heads rather than just buying the correct intake manifold. :confused:
ENSIGN
I tryed doing this last year,did'nt work on the 12 bolt manifold the bolts go in on a angle and on the 8 bolt manifold the bolts go in straight up and down.
Ayuh,... I donno just What you were Trying,...
But,...There are 3 Different intake manifold bolt patterns for SBCs..
This quote describes the 1st,+ 3rd patterns...
The 2nd pattern has the 4 center bolts Vertical...
ENSIGN
Thanks,I'll have to remember that.(I hope)
Bt Doctur
The heads I have are PRO-RT ,center or edge valve cover bolts, large valves.I suspect there some type of racing style head . And I have 2 manifolds available to fit them.
Unless the cust locates a regular set ,there the ones going on the motor.
