What Year is my Force 90 HP S/N : OE032992 ??
Huason
Please:
I Need.
Year:???
Model:???
Version : ???
For this 90 HP Force
S/N : OE032992
A lot of Tnx.
Huason
roscoe
Re: What Year is my Force 90 HP S/N : OE032992 ??
We;come to iboats.
You have either a 1991 or a 1992 model.
There were several variations during those 2 years.
Should be able to narrow it down for you if:
You can post a photo of your ignition components and fuel pump.
Does your motor have 2 blue cd modules and 3 bright blue coils?
Does it have no cd modules, 3 dark blue coils, and a switchbox with terminal to attach the wires?
Or does it have a switchbox with bullet connectors on the wires?
Is the fuel pump square? or is it oval with 2 humps on it?
Huason
Tnx a lot for you interesting for help me..
Here are some pictures as you asking..
- CDI Module
- Coil Ignition
- Fuel Pump
I think too that is a 1991 or 1992.
I need the exact year.
Over the Fill Hole in the Lower Unit have a #4.... that is a Lower
Unit Type D.....
It?s mean that is a 1991D ?????????
Tnx a lot again...
Huason
Huason
In response to your Answer.
I Think that my Force
- Have no cd modules,
- Have 3 dark blue coils,
- Have a switchbox with terminal to attach the wires.
Is that correct...?
Can you help me ...are the pictures enough to get the real year??
Tnx
Huason
roscoe
No, not a 1991D.
That ignition switchbox was used from 1991H through 1992C and up to serial numbers OE039024.
Same for the fuel pump.
I believe you have a late 1992 model, either a 92B or 92C.
