What year is my Evinrude?
watersranchaz
The serial # is 5524R-12656. Also what is the horsepower and fuel mixture? Thanks
Bear
Re: What year is my Evinrude?
5524 Evinrude 1962 <br />5.5 hp @ 4000 rpm<br />8.84 cu.in. = 144.8 ccm <br />2 cylinder<br />55.5 lbs. = 25.2 Kg <br />prop 8 x 7 1/4 , 2 blade <br />gear ratio 15:26<br /> A picture <br /><br />Probably 50:1 fuel mix<br /><br />Edit: "Model CD19 is a 1962!! CDL would be a long (20")shaft. You should be using a 24:1 to 32:1 mix for fuel," as JB said in another post.<br /><br />CD19 is a Johnson 5.5 hp. I think they are the same engines as the Evin 5.5 hp. <br /><br />Let's see if someone knows for sure about your Evin 5.5 '62...
