What year did 200hp Evinrude change from Crossflow to Looper
Cdogtx
Trying to find out what year Evinrude quit making the 200hp crossflow and changed to a looper style motor
dehydrated
Re: What year did 200hp Evinrude change from Crossflow to Looper
If memory serves me right 1986 was the first year of the looper
Cdogtx
Thank you...I am looking at buying a 87' model, but before driving 2 years to see it just wanted to make it was a looper. This person doesnt know
Thanks, again
boobie
Get a model # off of it and post it back on here. You'll get an answer. 2 years ?????????? 1984 was the first year of the looper. 120/140 models.
dehydrated
Check the casting numbers on the heads should be 331490 if so at least those are worth some bucks too.But yes 1986 was a looper in the 200/225 models.Just curious how much?
Greg_E
The model number should be stamped in the freeze plug on the back of the block near the top. The current owner should be able to tell you that over the phone. You can check the model number at shop2.evinrude.com.
1986 and 1987 were small bore loopers. In 1988 they went to the big bore design, along with numerous other changes.
dehydrated: Is there something special about those heads that makes them in demand?
Cdogtx
I meant 2 hours drive (not years). I guess I should read what I type. Thanks for all the info. By the way, I can get the motor for $1000 on a junky boat.
Faztbullet
They are a small closed chamber head good for a 10 -15 psi compression increase when bolted on to a 3.0L, but you have to modify they water flow and t-stat to work properly.
Roberthill
Please explain :Looper?
:Crossflow?
