Thunderstruck
- Jan 5, 2004
- 10
I have a boat which has severe wear at the keel area,The wear is about 10ft long.There is one spot that is about 3 inches that is worse than the rest and I saw water seaping out.The boat was bought in September and I have not had it in the water yet(am doing A MAJOR REFIT).I have no problem fixing the keel area and when fixed plan on installing a KEEL GAURD.It looks like most of the damage was caused by bad rollers because the middle is out on all of them.I have no way of getting to the area without ripping up the floor.That would be very hard to do.I am woundering if I should drill some holes in the area and let dry and then repair and if so what should be used to fill the holes.I was planning on using MARINE TEX,Thanks
