Waterskipper
- Jun 17, 2008
- 8
Replacing the transom in the 76 Starcraft Aluminum. Drilled oversize holes for the mounting hardware with plans to drill actual size during installation. Can I coat with another layer of resin put it back together and drill the regular size holes and fill with silicone caulk when putting the bolts in. Another thought would be to redrill the oversize holes and make the resin paste even thicker with the wood flour. I'm open for suggestions. The picture is a 2 inch oversize for the back splash drains. I also have some 1" holes for the mounting bolts that had the cracks also. Appreciate your thoughts.
