Engine is an inboard crusader 270. Today I installed a new starter, cranked the engine and it started right up. Turned it off. Went to start it again and crunch...... Took out the starter and the starter housing around the benDix drive was...is cracked. Along with this, the flywheel is missing 4 teeth.
I have changed many starters and engines, however I have never seen this. Did the starter crack the teeth on the flywheel or did the missing teeth crack the starter housing?
