What water pump kit do I need
Woody70
I need to rebuild or replace my water pump don't know what kit I need to get.
the serial number on the sterndrive is 3440864.
Engine serial number is 2362287.
I'm hoping somebody will be able to tell me which pump kit I need.
thanks.
achris
More fish than mountain goat
That serial number is for an MC-1 drive, but here's the 'hook'. The serial number is on the top (drive shaft) housing, and the lower (gear) housing could have been changed. You need to take the drive apart to see exactly what you have...
What you're looking for....
Does the lower drive shaft have a 'pre-load' pin at the top?
If not, it's an MR or Alpha One gear housing, and requires a 46-96148A8 kit for the housing and impeller and a 46-44292A3 base.
If it has a pre-load pin, you have an MC1 or R gear housing and require the same top kit (46-96148A8) but either a base with a 'flush' hole or without. With the flush hole (for early MC-1) is 46-48748T1 base, without is a 46-57234T1 base.
Hope this helps,
Chris............
Woody70
Thanks for the help.
I'll pull it off to see what I got
