What Volvo outdrive do I need?
jczimm24
Hello:
I recently purchased my first I/O and I learned shortly thereafter that the outdrive was in worse shape than I had thought. My mechanic is recommending I replace it. I am shopping around for a used one and I was wondering what Volvo penta I would need to replace a 315 Indmar engine. Any advice?
Someone has recently offered me a free used outdrive from a 175 HP power engine but something tells me the two are not going to be compatible. Any guidance here?
Many thanks
John
180shabah
Re: What Volvo outdrive do I need?
What do you have now??
Year?
Model?
S/N?
How much are you replacing??
Drive only? drive and engine??
jczimm24
Right now I have a 1988 volvo duo-prop. I am just replacing the drive. The engine is a 2005 315 Indmar and it is brand new.
bigbrownbuku
Master Chief Petty Officer
the drive model is what you need to post. transoms are sometimes drive specific. 1988 is most likely a 290dp. if you are unsure a photo would clear it up.
that is a very dependable drive why is it a write off?
jczimm24
I can't get photo because it is under wraps for the winter.
I am writing it off because it was not maintained from what they are telling me it is not worth the cost of repairs. I have no idea what these cost brand new or redone. Any ideas on that? If it is a trade off between spending the $ to fix it versus spending the same amount for a new/redone outdrive I would rather do the latter.
Don S
Nobody can tell you what one is going to cost if they don't know what you have. Was it a single prop? Dual Prop? Did it have trim? or just a Mechanical lift. If it has trim, are the trim cylinders inside a stainless bracket?
Maybe this chart will help you ID your drive.
Volvo Drive Chart
jczimm24
Good point. Sorry to throw a random question out there when all I know is that it is a duoprop, had trim, white and a 1988. That chart is very useful. I am going to have to take a look at it and try and figure out what it is that I have. It definitely looks most like the DP-G.
This is a whole new world to me and I am a bit confused and disappointed because the condition of the outdrive was significantly less than described.
