What upgrade engines will replace 2.3 in 89 Bayliner, marine and automobile?
bobsomm
FRIEND did not winterize my 89 bayliner 2.3 and block cracked, exhaust manifold cracked. Was not happy with low power and ask if someone can recommend economical replacement/Upgrade engine to consider. Tried 2.3 from ford truck but was too long. Mechanic ripped me off and left town. Need to fix or part it out. Has Cobra II outdrive. What will fit? Thanks Bob
Levinz11
Re: What upgrade engines will replace 2.3 in 89 Bayliner, marine and automobile?
The Ranger 2.3 should have been the same block. What didn't fit? Do a search in this forum...you should find your answer.
Speak
Best option would be to replace with pully to prop 3.0L from a donor boat. You will have to install a front engine mount in thou. Your biggest problem with getting hat 2.3 back up and running will be replacing that exhaust manifold. Very expensive and hard to find a good one. Aftermarket are a available but over a grand online I have the same set up and plan putting a 3.0 merc in it. Good luck man
Stu
bobsomm
Thanks Levinz11, Stu and Dale
The guy doing the work turned out to be a druggie and ripped off a bunch of us seniors before he disappeared. I can't say for certain that the engine I bought actually would not work, just that he told me this before I caught on that he was sucking us dry. He had gotten rid of the engine and I got ba k 50 cents on the dollar.
I'll look into a 3.0L. Someone told me last Fall that I can go up to a 5.0....
Thanks again
Peace Bob near Seattle.
Thanks again
Ayuh,....You can go all the way to a Big Block if ya want,...
Whatever ya buy, you need from the Pulleys to the Prop, to do the swap,...
That means buyin' a rotten boat, 'n junkin' it for it's driveline to put into Yer hull,...
Which brings up an important Question,...
Just how much in Love with yer hull are you,..??
If yer Not turnin' yer own wrenches, sell what you've got, 'n go buy another Runnin' boat,...
the 2.3 is the SAME block and heads in the ford Ranger, which is just an updated ford Pinto motor. sounds like you will also need to source a new exhaust manifold.
However as Bond-o put it, How in love with your boat are you? to repower your existing boat with a 2.3 liter will be in about the 1 BOAT unit range by the time you get a decent running 2.3, new manifold, gaskets, incidentals, etc. (1 BOAT unit is $1000 for Break Out Another Thousand). A motor swap will be a minimum of 1 BOAT unit and may be as high as 4 BOAT units
Speak
He will also need the block with the distributor hole. I think the ranger blocks have no hole. Done one correct me if I'm wrong.
Levinz11
Love that, may steal it.
