what type of old evinrude do i have?
climbhigh
i dont think the cover is for this motor,it reads as a sport twin. serial# 10302D-E08161? any help please....thanks
roscoe
Re: what type of old evinrude do i have?
Sorry, I can't help you with what the cover should read, but here is a bit of info.<br />Hopefully someone else can help.<br /><br /><br />10302<br />Evinrude<br />1963<br />10 hp at<br />4500 rpm max<br />16.6 cu.in. = 272.0 ccm<br />2 cylinder<br />69 lbs. = 31.3 Kg<br />8 1/4 x 8 1/2 prop size<br />13:23 gear ratio
JB
24:1 fuel mix, Climbhigh.<br /><br />Welcome to iboats. :)
Paul Moir
A 10hp 16.6CID is a Sportwin, but the cover could possibly be from a previous year (only '59-'63 though)?
climbhigh
thank you for the info. now if i can just get her running. i rebuilt the carb, but stil can not get her to fire up.when i first got the motor a few weeks ago, i pulled the plugs and she had fire on both plugs. since then though it has been a no go. i was wondering if hte kill switch might be shorting out. i would sure like to be able to fix and run this one without having to pay 60.00 bucks a hour to take her to the shop, dont know if it would be worth it.th
climbhigh
