Re: What top speed should my celebrity have?
I just bought the boat and this past weekend was the second time i took it out. The guy i bought it from said he did about 40-45 mph. He also told me that he tried using a 4 fin prop and didnt like it so he switched back the prop thats on it now.
So this weekend I realized my fuel pump was bad, so i replaced it. There was about 1/8 of a tank of gas from last season still in it(which was a half tank before when i was getting 12mph). I filled it up with fresh gas, took it back out and slowly increased speed after messing with the trim. I eventually got it up to about 35 mph at 4200 rpm. I think the fuel pump was just really weak(it would still turn on and deliver gas to the carb), but after replacing it with the new one i could defiantly see that gas was getting to all 4 bbl on the carb. This time i only had 3 adults, and i also had the massive bench seat taken out so that i could get to the motor more easily. I think i shed at least 500 pounds since the last time i took it out. I had my uncle with me who has been boating for at least 20 years mess with the trim and everything, and he too got it up to about 35 mph. With the fresh gas the motor was so much more responsive with the throttle. The longer i had it running the better it got.
The numbers on my prop were J 14.25 x 21p, aluminum 3 fin. When i took it off i noticed the back end of it was bent inward on the lip portion that sits inside the outdrive housing. The second prop i tried was a stainless steel 3 fin in good condition, the only number i could see on it was 23. I did not notice a difference between the two props, but i think i may have switched back to my original prop before replacing the fuel pump.
I forgot to find out the gear ratio on my outdrive.
There are a significant amount of barnacles on the hull. The guy before had it in salt water all last season.
The spark plugs all looked good, but I will replace them. When i first got the boat, i reset the timing and replaced the starter. As far as a tune up i think it has not had one for at least a season or two.
Recommended max rpm for my motor is 4400-4800, so im getting 35 mph at 4200. I will replace the spark plugs, run through another tank of gas, change the oil and then see if i can get it up to 40. If not then i should consider replacing the prop to get it up to 4400-4800 range?
