chiefcatchemall
- Jul 24, 2009
- 197
Well I am going to rip my powerhead off and take a look at the piston heads and cylinder walls to take a look and see if the cylinders are scored at all. My question is when Im there what should I use to manually decarb the piston heads and what it is I should use to clean the cyl walls?...When I am finished cleaning it shouldnt I put a few drops of my 2 stoke outboard oil in and coat the walls and piston heads? I know I obviously dont want to use anything that will scratch up the cylinder walls, but I was just curious as to what you guys use or what works best to get clean?
