What to use in large holes?
Azlo
What do u guys suggest for the fill in the large holes on my aluminum transom?
Marine bondo? jb weld? This transom has had almost everything installed on its rear. The biggest hole is about an 1 1\2". The PO had a big @$$ bolt to cover it. :mad:
Gnarly
Re: What to use in large holes?
fill the holes with marine sealant and rivet a doubler patch over with sealant on the faying surfaces
fishinpa
Looks like 2 of the holes are for a tie down, round -about 3/8 in and 1 above the other.
They are nice to have on there and its an easy fix for two holes should you have the same holes on the other side that takes care of 4 !
fish
