jonneythompson
- Nov 2, 2001
- 9
Since it seems that most of you are extremely knowledgable about boats and motors, what should I look for as potential problems with a used motor for a boat I am considering buying?? <br /><br />I noticed when I took off the water pump hose and poured anti-freeze in that the water coming out was dirty, and I would see some rust. Is think normal, I don't believe the boat has been run in quite some time. Maybe 6-12 months. <br /><br />Also should the prop make a sloppy sound when ran at med-high throttle? I have not had it in the water yet, but I DID do a compression check on the outdrive. <br /><br />Amy suggestions - I know Jeeps, not boats.
