Re: what to do?
yes on the oil /.Look hard for gas that has no ethonol.Those older engines certainly dont have the hose that works ok with it.Also,over time,the coils in those engines deteriorate,thats a FYI.Depending on how much your going to use it will dictate alot on the maint.Back in the day,yearly tune ups included new points,condenser,plugs ,gear oil and usually an impeller.If you decide to change the components under the flywheel,look closly at the coils for cracking to the insulated covering.If cracked,do yourself a favor and change both of them.It will run sometimes with some cracking .But over time,especially after the engine heat gets up there ,it can get worse quick.You dont want breakdown.
