Long story short - I drove the boat for about an hour without any oil* before the engine stalled upon deceleration and wouldn't start back up. Once back (towed) I realized my mistake and switched it over to the correct fuel and was able to start it but only with the fast idle up..if I lower the fast idle it stalls out. How much damage did I do...should I just run it with the correct fuel for a while on fast idle to see if I can fix things? It's running, but I don't know much about engines so I'm not sure that means much. It's a Mercury 25hp (25EL 2002)
* The thank wasn't empty when I added fresh gas so there was some oil but the ratio would have been super low.
