Re: What to check when buying a used mercruiser 3.0
Thank you very much for all of your great information guys. I REALLY appreciated it!!! However, i have many issues. Can't believe that everybody i talked to, told me that these motors would swap out no problem. any how, i think it can work, just need to figure out the best plan of action???
Ok, so here's where I stand... Swapped the rear motor mounts with no problems and it worked like a champ. starter and flywheel stayed and match up fine, luckily. looks fine and works fine I think. Starter cranks and flywheel turns.
HERE'S A BREAKDOWN OF ALL OF MY PROBLEMS... ANY GOOD NEWS?
********************Ignition problems************************
I went ahead and swapped the ignition system from the 91' over to the 81'... ((IGNITION MODULE (think that's what it is?), IGNITION COIL, DISTRIBUTOR(electronic spark timing) , and the CIRCUIT BREAKER))
Everything seemed to go pretty smooth...I had to change a couple connectors but no major problems, I thought at least. However, for some reason, now I have NO SPARK ON ANY CYLINDER, OR FROM COIL TO DISTRIBUTOR? Why?
I did have strong spark with the other older style ignition system that i took off last night!!!(slave solenoid, coil, and distributor with rotor...thought it had points, but doesn't). The only reason that I changed it was because i didn't think i could just plug that harness into the female on the boat without problems? should I have left it or did I possibly hook something up wrong? my manual doesn't have a diagram of a est ignitions system. HELP! Can I test these components without the motor running. It Still turns over strong, JUST NO SPARK!!!
I swapped the valve cover so I could try to hook up the control cables in the boat the way they were on the old motor. I ran the wires to the neutral safety on the valve cover too but i guess right now they are just going to a dead end at the Mercruiser harness as the boat is sitting on a flat trailer next to the old motor. could this be my no spark issue? I tried bypassing it by connecting the black and purple/white wire together with no luck?
I Have two white wires coming out of the distributor that don't go anywhere.
I have one black wire that was spliced to a white wire going to the motor side of the harness... that's how i found it on the old motor before it came out. I saw videos on Youtube that looked the same?
my buddy gave me this boat and said the old motor was running before he broke a starter bolt and let it sit with no plugs for a year. I would assume that everything was hooked up correctly if it was running before.
************** Fuel pump****************
I have a total of four fuel pumps. one that"s on the older motor. two that came with the motor i just bought (filter on bottom) and one that is mounted on the motor(81') that i just bought. It looks different and not sure if i can get the fuel metal fuel line to the carb with this pump? have you seen one of these before? (should be visible in my attached pics). Which pump should i use and is there gasket/diaphragm kits for these? next issue....
*******Carburetor/ Choke/ throttle/shift linkage/ manifold/ exhaust******
As you can see in the pictures The old motor has a black carb. that i havent identified (mercarb?) that only matches the bolt pattern on the manifold from the old motor. (its in pretty bad shape)
The carb that came on the new motor (81') is a Rochester two jet that has no connection for the choke or does it??? This carb only will fit on the manifold that is on the new motor(81') as some of you know.
The problem is that the Rochester carb looks like it may work but there is nowhere for the wires from the harness (electric choke), the mechanical choke seems incomplete. ALSO, the linkage that should connect to the throttle cable(from the valve cover) doesn't have an arm to connect to? to short, and i cannot swap it from the other carb. Can i connect the cables on the manifold, and rig the existing, or non-existing mechanical choke, and swap the valve covers back? will this work? P.s. THE ELECTRIC CHOKE WILL FIT ON THE THE ROCHESTER CARB, BUT I STILL HAVE THE ISSUE OF THROTTLE LINKAGE... UGH!!!
I really dont have the money to spend on another manifold, and im not sure if i can get the old one off or if it will work. Furthermore, Im not sure if the Mercarb will work on the new motor(81) even if i do change the manifold? In that case I still need to figure out the spark issue and fuel pump.
Should I try to change the manifold and carb, and use the old carb that has the electric choke and definitely will mesh with the throttle cable linkage and deal the spark issue, the fuel pump issue, and i maybe a new exhaust elbow too? (how good of condition do the elbows need to be to work?)
On the other hand, could I leave the Rochester carb and the existing manifold on the new motor(81'),change back to the older style ignition and wire harness (if i can figure it out), and deal with the throttle linkage, choke linkage, fuel pump, exhaust and wonder what will happen when i plug the harness in on the boat? will everything get power still?
with either alternative i need to figure out the spark issue. two different harness's two different ignitions? I feel like i need the one harness that matches the neutral safety switch(On the valve cover), and the electric choke, but the other harness is the one that worked on the motor and had good spark, but im not sure if it will match the circuitry on the boat side???
WHAT THE HECK SHOULD I DO MAN!!!! AHHHHH. If i wasn't broke i would go buy the parts i need if i could find them. Actually, I guess if i wasn't broke i wouldn't be going through all this hassle. lol I do enjoy it but its frustrating.
IF ANYONE ACTUALLY MADE IT THIS FAR, YOUR AWESOME! THIS SHOULD BE A VERY HELPFUL THREAD TO LOTS OF PEOPLE IF I CAN GATHER ALL OF THE ANSWERS. THANK YOU ALL SO MUCH!!!!
